Audi TT-RS
                • Als je een beetje knappe race kuip in je TT RS wilt hebben dan neem je de Recaro RMS 2700G.
                          • Last edited by The Pretender; 30/12/2018, 00:27.
                            • Last edited by The Pretender; 30/12/2018, 00:28.
                              • TTE700 Upgrade Performance Turbocharger 2.5 TFSI
                                Introducing our TTE700 performance turbocharger based on the original turbocharger to new higher output specification. Offering an upgrade power upto 700PS
                                Engineered & Enhanced
                                At the core of our TTE700 is a much larger TTE compressor wheel, chosen because it is highly efficient and creates an extremely high flow for comparative size. Re-Profiled compressor cover to optimised tolerance to ensure maximum compressor efficiency is given.
                                We CNC mill the exhaust turbine housing to accept a larger turbine and shaft.
                                Special profile 360 deg high-performance motorsport journal bearing is fitted, to remain durable at higher loads with no loss in transient response. The actuator used is sprung OE unit
                                Equilibrium
                                Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
                                Product Highlights:
                                • Up to 700HP / over 900Nm
                                • Original BWTS turbocharger as base part
                                • Very early response
                                • Billet Milled TTE compressor
                                • Reinforced BWTS TTE actuator
                                • High Flow Turbine
                                • O-ring sealing
                                • Reinforced axial and radial bearing
                                • Proven TheTurboEngineers quality
                                • TTE CNC milled OEM intake pipe included
                                • Made in Germany
                                New price 4536.97 Euro net
                                To recondition and upgrade a supplied used turbocharger price is 2436.13.00 Euro net
                                (For customers in EU countries 19%+ VAT Must be added to prices above unless having a valid VAT ID)
                                Shipping does vary but 45.00 euro is a good guide for Europe-wide.
                                    • Eventuri Carbon Ansaugsystem für Audi TT RS 8S.
                                      • Last edited by The Pretender; 30/12/2018, 16:40.
